1997 dodge ram 1500 4×4
im not getting fire to the coil ive already replace crank sensor
1 thought on “1997 dodge ram 1500 4×4”
  1. I will just assume this is the 5.9L engine.
    The coil gets a power signal from the PCM on BLK/GRY wire and negative(ground) is on the DRK GRN/ORG wire. The trigger comes from the Distributor. (the other wire, the diagram does not associate a color)
    1997 Dodge Ram1500 Ignition Coil Wiring Diagram
