Hose Location 2006 Kia Rio
KIA RioI had to take apart to have head work done. I have head and throttle body
back on but not sure where the two hose connections connect to. I have been unable to find a repair manual for this car. I have had it apart for a while so without a book having some problems. If you can help I would appreciate it. If you know where I can get a manual that would be great.
Looks like one is for the heater hose and the other is for the vacuum brake booster. Should be easy enough to determine which one will reach to each outlet.
There is a PCV hose that connects tot eh PCV valve. There is also a breather hose.
For a manual follow the “Manuals” tab above.
