Back Wheels Slid 2016 Honda Accord
2016 Honda CivicI did a hard turn at around 30ish mph and my back wheels slid a little bit. (I have a fwd car) After the wheels screeched, as the car started to go forwards I heard a sound somewhat like “crrrrrrnn” What was that?
Back Wheels Slid and Made Noise
More than likely the noise was from the traction control unit. When the wheel slip the speed sensors send a signal to the abs unit to apply some brake pressure using the abs motor. This is the most likely scenario for such a noise. I do not think it is anything to worry about. It was just the vehicle doing what it was designed to do in that particular situation. If it starts to happen when you are not Hot Roding, then worry.
