Liftgate 2000 Dodge Caravan
2000 Daodge CaravanRear latch handle does not work. You can open it from the inside through a hole. Do I need a latch handle or an actuator or both?
you will need to remove the panel and inspect the latch handle to see if anything has become detached or broken. If the handle is broken then replace the handle, etc.
