2007 Ford Freestar Minivan
My problem is this. I have been getting vibration and hesitation like it looses power momentarily with a jerk/bump/clunk ate the end of the hesitation while driving. The vibration and hesitation do not always happen simultaneously. This happens at speeds above 45 MPH. The vehicle seem to shift normally and does not have any knocking or engine noise. I was thinking Drive/half shaft or related issues but am no mechanic. What could this be?
1 thought on “2007 Ford Freestar Minivan”
  1. Before diving further into what it could be. Is the Check Engine light on? What are the codes.
    This code be as simple as a misfire and should store a code to tell us which cylinder needs help.
    The vibration may be a separate issue from the hesitation and may just be that the tires need to be balanced since you only notice it above 45 mph.
