I need to replace a/c heater blower motor. Can I please get some assistance where it is, where to to begin, anything?
Keywords:Mark 8
1.Lower the glove compartment door to gain access to the rear of the evaporator case.
2.Disconnect the blower motor electrical connector.
3.Remove the two screws and remove the A/C evaporator air control venturi and automatic temperature control sensor hose and elbow.
4.Remove the two screws and remove the A/C blower motor speed control.
5.Remove the attaching screws and pull the A/C blower motor out of the A/C evaporator housing.
6.Pull the blower motor wheel retainer off of the A/C blower motor shaft and remove the A.C blower wheel from the shaft.
To install:
7.Install the A/C blower wheel on the A/C blower motor shaft.
8.Install the A/C blower motor assembly in the AC evaporator housing and install the last screw removed.
9.Install the A.C blower motor speed control module.
10.Install the A.C evaporator air control venturi and connect the automatic temperature control sensor hose and elbow.
11.Connect the A/C blower motor electrical connector.
