#3 spark plug blew out of engine block, spark plug wont thread into hole as if stripped threads inside hole. how can i fix?
Short answer:
repair the threads and replace the spark plugs.
Long answer:
Does not qualify under the Ford spark plug settlement agreement.
Threading bit fell into the spark plug hole into the piston chambers
I would suggest a magnet and long needle nose pliers. If you can not remove it the head assembly will need to be removed.
