2004 volvo xc70 remote starter
2004 Volvo xc70Hello I have a 2004 Volvo xc70 and was wondering if it is possible to put a remote starter in it while using the original factory keys?
Of course you can install a remote starter on a Volvo xc70. The remote starter uses a key thob to activate the starter. The thob can be easily attached to any set of keys or carried separate.
2004 Volvo xc70 starting system wiring diagram
Use the wiring diagram to help assist you if you decide to install a remote starter on your xc70 yourself. Make sure to disconnect the battery before you start installation. Follow the instructions provided from the manufacturer of the remote starter. Test the operation several times to insure you won’t have any issues once you leave home.
