Windows stopped working
All four of my windows stopped working at the same time. We have checked the fuses and replaced the 30 amp circuit breaker and they still don’t work. Can you tell me what it might be and how to fix the problem?
Grab a multi-meter and dive into the wiring harness. Check your negative and positive. Might keep an eye out for a break in the wiring harness near or at the driver side door jam. This is a common place for the wiring to become damaged. Use the wiring diagram provided to assist in tracing down your issue.
