Does the speaker cover on the passenger front door come off without having to remove the door panel ? It is dented in and I just want to pop it back to shape. thank you
The speaker cover is part of the door panel. Removal of the door panel will be required.
Door panel removal 2011 Lincoln MKS
Removal and Installation
All trim panels
1.Pull outward and remove the sail panel. •If equipped, disconnect the electrical connector.
2.Remove the front door inside handle assembly bolt cover.
3.Remove the front door inside door handle assembly bolt. •To install, tighten to 7 Nm (62 lb-in).
4.Remove the front door trim panel center bolt. •To install, tighten to 7 Nm (62 lb-in).
5.Remove the trim panel grommet and remove the front door trim panel rear screw. •To install, tighten to 1 Nm (9 lb-in).
6.Remove the front door trim panel lower screws.
7. NOTICE: Avoid pulling directly on the upper rear corner (vinyl portion) of the door trim panel during removal to prevent damage to the door trim panel.
Remove the front door trim panel. •Pull the front door trim panel outward to release the retaining clips.
•Disconnect the inside door handle cable.
•If equipped, disconnect the electrical connectors.
Window garnish moulding
8.Remove the window garnish moulding screw.
9.Remove the window garnish moulding.
All trim panels
10. NOTICE: To avoid damage to the door trim panel, remove any retaining clips from the body and attach them to the door trim panel.
To install, reverse the removal procedure.
