My air conditioning quit. The compressor spins, I checked Freon its fine. I put the gauges on it and it read 55psi low side, 100psi high side. Replaced expansion valve and recharged. Same thing.
This is an indication of a restriction in the system. Most likely the condenser is where the restriction is. You can flush the condenser and test for restriction or replace it.
