Code P2006 2011 Hyundai Tuscon
2011 Hyundai Tuscon
CBD II codes: P0302, P0170, and P2006 Can the engine problems be resolved by using a fuel additive/cleaner and replacing the fuel filter?
I would have to say NO. You may review the code information and see it is going to take a bit more than a filter and fuel change.
Hyundai Code P2006
Intake Manifold Runner Control Stuck Closed Bank 1
Code P2006 Probable Causes
  1. Sensor or solenoid faulty
  2. Connector terminal contact is damaged or corroded
  3. Wire harness – Check harness for correct voltage, open, short to ground or short to voltage
  4. Update control unit software – Check for the latest control unit update
  5. Powertrain or Engine Control Module faulty
Hyundai Code P0170
Fuel Trim (Bank 1)
Code P0170 Probable Causes
  2. Update control unit software – Check for the latest control unit update
  3. Powertrain or Engine Control Module faulty
  4. Fuel pressure – Pump, regulator, filter or lines
Hyundai Code P0302
Cylinder 2 Engine Misfire Detected
Code P0320 Probable Causes
  1. Update control unit software – Check for the latest control unit update
  2. Powertrain or Engine Control Module faulty
  3. Fuel injector(s) faulty
  4. Ignition system – Ignition module, coil, spark plugs and wires
  5. Fuel system
