Not getting fuel to the injectors. Fuel pump is working replaced fuel filter also. Any suggestions?
DD: Fuel Rail Pressure (FRP), Fuel Rail Temperature (FRT) and Fuel Rail Pressure Temperature (FRPT) Sensors
2004 PCED On Board Diagnostics | SECTION 5: Pinpoint Tests |
Procedure revision date: 03/24/2005 |
DD: Fuel Rail Pressure (FRP), Fuel Rail Temperature (FRT) and Fuel Rail Pressure Temperature (FRPT) Sensors | ← DD: Introduction |
DD1 DTC P0192: DETERMINE THE PRESENT FRP V PID VOLTAGE
- Key ON, engine OFF.
- Access the PCM and monitor the FRP V PID.
Is the voltage less than 0.25 V?
| Yes | No |
Key in OFF position. For F-150 Heritage 5.4L Dedicated NGV, and Crown Victoria Dedicated NGV, GO to DD3. For E-Series Dedicated NGV, and F-150 Heritage Bi-Fuel, GO to DD30. For all others, GO to DD2. | Key in OFF position. GO to DD28. |
DD2 CHECK THE FRP SENSOR FOR LEAKS
- Key ON, engine running.
- Idle the engine for 2 minutes.
- Key in OFF position.
- REMOVE the FRP Sensor vacuum hose.
- INSPECT the FRP Sensor and vacuum hose for traces of fuel.
Is fuel present?
| Yes | No |
Key in OFF position. INSTALL a new FRP sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | GO to DD3. |
DD3 INDUCE THE OPPOSITE FRP SENSOR VOLTAGE
- FRP Sensor connector disconnected.
Is the voltage greater than 4.5 V?
| Yes | No |
Key in OFF position. INSTALL a new FRP sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | GO to DD4. |
DD4 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
- PCM connector disconnected.
- Measure the resistance between:
( + ) PCM Connector, Harness Side ( – ) FRP Sensor Connector, Harness Side FRP FRP
Is the resistance less than 5 ohms?
| Yes | No |
| GO to DD5. | REPAIR the open circuit. |
DD5 CHECK THE VREF AND SIGRTN CIRCUITS FOR OPEN IN HARNESS
- PCM connector connected.
- Measure the voltage between:
( + ) FRP Sensor Connector, Harness Side ( – ) FRP Sensor Connector, Harness Side VREF SIGRTN
Is the voltage between 4 V – 5.5 V?
| Yes | No |
Key in OFF position. GO to DD6. | GO to C1. |
DD6 VERIFY DIAGNOSTIC TOOL COMMUNICATION
- Connect a 5 amp fused jumper wire between the following:
Point A FRP Sensor Connector, Harness Side Point B FRP Sensor Connector, Harness Side FRP SIGRTN - Access the PCM and monitor the FRP PID.
Does a diagnostic tool communication concern exist?
| Yes | No |
Key in OFF position. GO to DD7. | Key in OFF position. GO to DD8. |
DD7 CHECK THE FRP V CIRCUIT FOR A SHORT TO VREF
- Remove the jumper wire(s).
( + ) PCM Connector, Harness Side ( – ) PCM Connector, Harness Side VREF FRP
Is the resistance greater than 10K ohms?
| Yes | No |
INSTALL a new PCM. (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)). | REPAIR the short circuit. |
DD8 CHECK THE FRP CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
- Diagnostic tool connector disconnected.
( + ) PCM Connector, Harness Side ( – ) PCM Connector, Harness Side FRP SIGRTN - Measure the resistance between:
( + ) PCM Connector, Harness Side ( – ) Vehicle Battery FRP Negative terminal
| Yes | No |
DD9 DTC P0193: DETERMINE THE PRESENT FRP V PID VOLTAGE
Is the voltage greater than 4 V?
| Yes | No |
| GO to DD10. | GO to DD28. |
DD10 CHECK THE FRP SENSOR FOR LEAKS
Is fuel present?
| Yes | No |
Key in OFF position. INSTALL a new FRP sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | GO to DD11. |
DD11 CHECK THE FUEL PRESSURE
Is the pressure greater than 827 kPa (119.9 psi) for Dedicated NGV or greater than 482.6 kPa (70 psi) for all others?
| Yes | No |
For Dedicated NGV GO to DD23. For all others: GO to DD14. | Key in OFF position. For Dedicated NGV GO to HB1. For all others: GO to Z1. |
DD12 DTCS P0190 AND P0191: CHECK FOR FUEL PUMP DTCS
Are DTCs P0230, P0231, P0232, P1233, P1235, or P1237 present?
| Yes | No |
| DISREGARD the current diagnostic trouble code (DTC) at this time. DIAGNOSE the next DTC. GO to Section 4, Diagnostic Trouble Code (DTC) Charts. | GO to DD13. |
DD13 IS DTC P0191 PRESENT IN THE KOEO OR KOER SELF-TEST?
Is DTC P0191 present in the KOEO or KOER self-test?
| Yes | No |
| GO to DD19. | GO to DD90. |
DD14 CHECK THE VREF & SIGRTN CIRCUIT(S)
| Yes | No |
Key in OFF position. GO to DD15. | GO to C1. |
DD15 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
| Yes | No |
| GO to DD16. | REPAIR the open circuit. |
DD16 VERIFY DIAGNOSTIC TOOL COMMUNICATION
| Yes | No |
Key in OFF position. GO to DD17. | Key in OFF position. GO to DD18. |
DD17 CHECK THE FRP CIRCUIT FOR A SHORT TO VREF
| Yes | No |
DD18 CHECK THE FRP CIRCUIT FOR A SHORT TO POWER
( + ) FRP Sensor Connector, Harness Side ( – ) Vehicle Battery FRP Negative terminal
Is the voltage less than 1 V?
| Yes | No |
| GO to DD19. | Key in OFF position. REPAIR the short circuit. |
DD19 INSPECT ALL THE VACUUM HOSES CONNECTED TO THE INTAKE MANIFOLD FOR LEAKS
- FRP Sensor connector connected.
- Allow the engine idle to stabilize.
- Inspect all the vacuum hoses connected to the intake manifold for leaks.
Are any vacuum hose concerns present?
| Yes | No |
| ISOLATE the fault and REPAIR as necessary. | GO to DD20. |
DD20 CHECK THE FRP CONNECTOR FOR DAMAGE OR CORROSION
- Inspect the sensor, wiring, and connector for damage, corrosion, or water intrusion.
Is a concern present?
| Yes | No |
| REPAIR as necessary. | GO to DD21. |
DD21 CHECK THE FRP PID
- Record the FRP PID value within 5 seconds of the key off.
- Relieve the fuel pressure. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release or Fuel Line Evacuation procedure.
- Disable the fuel pump.
- Record the FRP PID value within 5 seconds of completing the fuel system pressure release procedure.
Is the difference between the recorded FRP PID values greater than 34 kPa (5 psi)?
| Yes | No |
For Dedicated NGV and Bi-Fuel vehicles, GO to Pinpoint Test HB. For all others, GO to Pinpoint Test HC. | GO to DD22. |
DD22 COMPARE THE FRP PID TO THE MECHANICAL GAUGE
- Connect a mechanical fuel pressure gauge.
- Monitor the mechanical gauge.
- Compare the FRP PID value to the mechanical gauge.
- Pressurize the fuel system. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release or Fuel Line Evacuation procedure to restore the fuel system pressure.
- Allow the fuel pressure to stabilize.
Are the FRP PID values within 34 kPa (5 psi) of the mechanical gauge readings?
| Yes | No |
For E-Series Dedicated NGV, and F-150 Heritage Bi-Fuel, INSTALL a new NG module. For all others, INSTALL a new PCM. REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM). | For Dedicated NGV and Bi-Fuel vehicles, GO to Pinpoint Test HB. For all others, INSTALL a new FRP sensor. REFER to the fuel system WARNING information at the beginning of Pinpoint Test HC. GO to Pinpoint Test HC. |
DD23 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
- NG Module connector disconnected.
( + ) NG Module Connector, Harness Side ( – ) FRP Sensor Connector, Harness Side FRP FRP
| Yes | No |
| GO to DD24. | REPAIR the open circuit. |
DD24 VERIFY DIAGNOSTIC TOOL COMMUNICATION
- NG Module connector connected.
Point A FRP Sensor Connector, Harness Side Point B FRP Sensor Connector, Harness Side FRP SRtn - Access the PCM and monitor the FRP PID.
| Yes | No |
Key in OFF position. GO to DD25. | Key in OFF position. GO to DD26. |
DD25 CHECK THE FRP CIRCUIT FOR A SHORT TO SREF
( + ) FRP Sensor Connector, Harness Side ( – ) FRP Sensor Connector, Harness Side FRP SRef
| Yes | No |
| INSTALL a new NG module. | REPAIR the short circuit. |
DD26 CHECK THE FRP CIRCUIT FOR A SHORT TO POWER
| Yes | No |
Key in OFF position. GO to DD27. | Key in OFF position. REPAIR the short circuit. |
DD27 CHECK THE FRP VOLTAGE PID DURING FUEL RAIL PRESSURE RELIEF
- Crank the engine.
Is the voltage between 0.4 V – 0.6 V?
| Yes | No |
INSTALL a new NG module. (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)). | GO to HB1. |
DD28 CHECK THE FRP VOLTAGE PID DURING FUEL RAIL PRESSURE RELIEF
- Disable the inertia switch.
- Monitor the FRP voltage while cranking the engine.
- FRP voltage decreases as the fuel rail pressure drops and stabilizes when the fuel rail pressure reaches atmospheric pressure.
Vehicle Low Limit High Limit F-150 1.0V 1.5V All others 0.2V 0.7V
Is the voltage value within specification?
| Yes | No |
| GO to DD29. | Key in OFF position. INSTALL a new FRP sensor. REFER to the fuel system WARNING information. |
DD29 PERFORM A THOROUGH WIGGLE TEST ON THE FRP HARNESS
- Reset the inertia switch.
- Perform a thorough wiggle test on the FRP Sensor harness.
Is the FRP signal stable?
| Yes | No |
| GO to Z1. | Key in OFF position. Repair as necessary. |
DD30 CHECK THE SREF AND SRTN CIRCUITS FOR OPEN IN THE HARNESS
( + ) FRP Sensor Connector, Harness Side ( – ) FRP Sensor Connector, Harness Side SRef SRtn
| Yes | No |
Key in OFF position. GO to DD31. | GO to C25. |
DD31 CHECK THE FRP CIRCUIT(S) FOR AN OPEN IN THE HARNESS
| Yes | No |
| GO to DD32. | REPAIR the open circuit. |
DD32 CHECK THE FRP CIRCUIT(S) FOR A SHORT TO SRTN OR GND IN THE HARNESS
( + ) FRP Sensor Connector, Harness Side ( – ) FRP Sensor Connector, Harness Side FRP SRtn - Measure the resistance between:
| Yes | No |
| GO to DD33. | REPAIR the short circuit. |
DD33 INDUCE THE OPPOSITE FRP SENSOR VOLTAGE
- Diagnostic tool connector connected.
Point A FRP Sensor Connector, Harness Side Point B FRP Sensor Connector, Harness Side FRP SRef - Key ON, engine OFF.
- (If the PID cannot be accessed, follow the NO action to take).
Is the voltage greater than 4.75 V?
| Yes | No |
Key in OFF position. INSTALL a new FRP sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | Key in OFF position. INSTALL a new NG module. Clear the PCM DTCs. REPEAT the self-test. |
DD34 DTCS P0181, P0182 OR P0183: ARE DTCS P0181, P0182 OR P0183 PRESENT IN THE KOEO OR KOER SELF-TEST?
Are DTCs P0181, P0182 or P0183 present in the KOEO or KOER self-test?
| Yes | No |
For E-Series Dedicated NGV, and F-150 Heritage Bi-Fuel, GO to DD75. For all others, GO to DD35. | For E-Series Dedicated NGV, and F-150 Heritage Bi-Fuel, GO to DD86. For all others, GO to DD88. |
DD35 DETERMINE THE PRESENT FRT PID VOLTAGE
- Allow vehicle temperatures to stabilize prior to temperature sensor tests.
- Normal test range 100 Deg C (212 Deg F) to 0 Deg C (32 Deg F).
- Access the PCM and monitor the FRT V PID.
Is the voltage greater than 0.4 V?
| Yes | No |
| GO to DD36. | GO to DD37. |
DD36 FRT SENSOR RESISTANCE TEST
- FRT Sensor connector disconnected.
- Sensor resistance measurements can be compared to the table above when the sensor temperature is known.
( + ) FRT Sensor Connector, Component Side ( – ) FRT Sensor Connector, Component Side FRT SIGRTN
Is the resistance between 2K ohms – 96K ohms?
| Yes | No |
| GO to DD37. | Key in OFF position. INSTALL a new FRT sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. |
DD37 CHECK THE FRT AND SIG RTN CIRCUIT(S) FOR AN OPEN IN THE HARNESS
( + ) PCM Connector, Harness Side ( – ) FRT Sensor Connector, Harness Side FRT FRT SIGRTN SIGRTN
Are the resistances greater than 5 ohms?
| Yes | No |
| REPAIR the open circuit. | GO to DD38. |
DD38 CHECK THE FRT CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
( + ) PCM Connector, Harness Side ( – ) PCM Connector, Harness Side FRT SIGRTN - Measure the resistance between:
( + ) PCM Connector, Harness Side ( – ) Vehicle Battery FRT Negative terminal
| Yes | No |
| GO to DD39. | REPAIR the short circuit. |
DD39 VERIFY DIAGNOSTIC TOOL COMMUNICATION
Point A FRT Sensor Connector, Harness Side Point B FRT Sensor Connector, Harness Side FRT SIGRTN - Access the PCM and monitor the FRT V PID.
| Yes | No |
Key in OFF position. GO to DD41. | Key in OFF position. REMOVE the jumper(s). GO to DD40. |
DD40 CHECK THE SENSOR SIGNAL CIRCUIT FOR A SHORT TO SIGRTN
( + ) FRT Sensor Connector, Harness Side ( – ) FRT Sensor Connector, Harness Side FRT SIGRTN
| Yes | No |
| GO to DD41. | REPAIR the short circuit. CLEAR the DTCs. REPEAT the self-test. |
DD41 CHECK THE SENSOR SIGNAL FOR A SHORT TO VREF
( + ) PCM Connector, Harness Side ( – ) PCM Connector, Harness Side FRT VREF
| Yes | No |
INSTALL a new PCM. (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)). | REPAIR the short circuit to VREF. |
DD42 DTC P0180: PERFORM A THOROUGH WIGGLE TEST ON THE FRT SENSOR HARNESS
- Perform a thorough wiggle test on the FRT Sensor harness.
Is the FRT signal stable?
| Yes | No |
| GO to DD44. | Key in OFF position. Repair as necessary. |
DD43 KOEO AND KOER DTC P0181: CHECK THE FRT_V PID
Vehicle Low Limit High Limit Vehicles with a 60-pin NG module 0.4V 5.0V All others 0.4V 4.5V
| Yes | No |
| GO to DD34. | The concern is elsewhere. RETURN to Symptom Charts, Symptom Charts for further direction. |
DD44 COMPARE THE PIDS AFTER STABILIZING THE VEHICLE TEMPERATURE
- Access the PCM and monitor the FRT_TEMP, CHT and ECT PIDs.
Are the temperature PIDs nearly equal in value?
| Yes | No |
The fault is not present at this time CLEAR the DTCs. REPEAT the self-test. | GO to Z1. |
DD45 DTC P0192: DETERMINE THE PRESENT FRP V PID VOLTAGE
| Yes | No |
For F-150 Heritage 5.4L Dedicated NGV, and Crown Victoria Dedicated NGV, GO to DD47. For all others, GO to DD46. | GO to DD58. |
DD46 CHECK THE FRPT SENSOR FOR LEAKS
- REMOVE the FRPT vacuum hose.
- INSPECT the FRPT and vacuum hose for traces of fuel.
Is fuel present?
| Yes | No |
Key in OFF position. INSTALL a new FRPT sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | GO to DD47. |
DD47 CHECK THE VREF AND SIGRTN CIRCUITS FOR OPEN IN HARNESS
- FRPT Sensor connector disconnected.
( + ) FRPT Sensor Connector, Harness Side ( – ) FRPT Sensor Connector, Harness Side VREF – Pin 2 SIGRTN – Pin 4
| Yes | No |
Key in OFF position. GO to DD48. | GO to C1. |
DD48 INDUCE THE OPPOSITE FRPT SENSOR VOLTAGE
| Yes | No |
Key in OFF position. INSTALL a new FRPT sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | GO to DD49. |
DD49 CHECK THE FRPT CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
| Yes | No |
DD50 DTC P0193: DETERMINE THE PRESENT FRP V PID VOLTAGE
| Yes | No |
For F-150 Heritage 5.4L Dedicated NGV, and Crown Victoria Dedicated NGV, GO to DD52. For all others, GO to DD51. | GO to DD58. |
DD51 CHECK THE FRPT SENSOR FOR LEAKS
- REMOVE the FRPT Sensor vacuum hose.
- INSPECT the FRPT Sensor and vacuum hose for traces of fuel.
Is fuel present?
| Yes | No |
Key in OFF position. INSTALL a new FRPT sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | GO to DD52. |
DD52 CHECK THE VREF AND SIGRTN CIRCUITS FOR OPEN IN HARNESS
| Yes | No |
Key in OFF position. GO to DD53. | GO to C1. |
DD53 CHECK THE FRP V CIRCUIT FOR A SHORT TO POWER
( + ) FRPT Sensor Connector, Harness Side ( – ) Vehicle Battery FRP – Pin 1 Negative terminal
Is the voltage greater than 10.5 V?
| Yes | No |
| Key in OFF position. REPAIR the short circuit. | GO to DD54. |
DD54 VERIFY DIAGNOSTIC TOOL COMMUNICATION
Point A FRPT Sensor Connector, Harness Side Point B FRPT Sensor Connector, Harness Side FRP – Pin 1 SIGRTN – Pin 4 - Access the PCM and monitor the FRP PID.
| Yes | No |
Key in OFF position. GO to DD55. | Key in OFF position. REMOVE the jumper(s). GO to DD56. |
DD55 CHECK THE FRP V CIRCUIT FOR A SHORT TO VREF
| Yes | No |
| GO to DD57. | REPAIR the short circuit. |
DD56 INDUCE THE OPPOSITE FRP V SENSOR VOLTAGE
Point A FRPT Sensor Connector, Harness Side Point B FRPT Sensor Connector, Harness Side FRP – Pin 1 SIGRTN – Pin 4 - Key ON, engine OFF.
Is the voltage less than 0.05 V?
| Yes | No |
Key in OFF position. INSTALL a new PCM. (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)). | Key in OFF position. GO to DD57. |
DD57 CHECK THE FRP AND SIG RTN CIRCUIT(S) FOR AN OPEN IN THE HARNESS
( + ) PCM Connector, Harness Side ( – ) FRPT Sensor Connector, Harness Side FRP FRP – Pin 1 SIGRTN SIGRTN – Pin 4
| Yes | No |
| REPAIR the open circuit. | INSTALL a new FRPT sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. |
DD58 PERFORM A THOROUGH WIGGLE TEST ON THE FRPT HARNESS
- Perform a thorough wiggle test on the FRPT Sensor harness.
| Yes | No |
DD59 DTCS P0190 AND P0191: CHECK FOR FUEL PUMP DRIVER MODULE (FPDM) DTCS
- Check for self-test DTCs.
Are DTCs P1233, P1235 or P1237 present?
| Yes | No |
| DISREGARD the current diagnostic trouble code (DTC) at this time. DIAGNOSE the next DTC. GO to Section 4, Diagnostic Trouble Code (DTC) Charts. | GO to DD60. |
DD60 CHECK THE FRPT CONNECTOR FOR DAMAGE OR CORROSION
| Yes | No |
| REPAIR as necessary. | GO to DD61. |
DD61 CHECK THE VREF AND SIGRTN CIRCUITS FOR AN OPEN IN THE HARNESS
Is the voltage between 4.5 V – 5.5 V?
| Yes | No |
| GO to DD62. | GO to C1. |
DD62 INSPECT ALL THE VACUUM HOSES CONNECTED TO THE INTAKE MANIFOLD FOR LEAKS
- FRPT Sensor connector connected.
| Yes | No |
| ISOLATE the fault and REPAIR as necessary. | GO to DD63. |
DD63 CHECK THE FRP PID
- Relieve the fuel pressure. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release procedure.
| Yes | No |
| GO to Pinpoint Test HC. | GO to DD64. |
DD64 COMPARE THE FRP PID TO THE MECHANICAL GAUGE
- Pressurize the fuel system. Refer to the Workshop Manual Section 310-00 Fuel System for the Fuel System Pressure Release procedure to restore the fuel system pressure.
| Yes | No |
| INSTALL a new PCM. REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM). | INSTALL a new FRPT sensor. REFER to the fuel system WARNING information at the beginning of Pinpoint Test HC. GO to Pinpoint Test HC. |
DD65 DTCS P0182 OR P0183: DETERMINE THE PRESENT FRT PID VOLTAGE
Is the voltage less than 0.4 V?
| Yes | No |
| GO to DD66. | GO to DD69. |
DD66 FRT SENSOR RESISTANCE TEST
( + ) FRPT Sensor Connector, Component Side ( – ) FRPT Sensor Connector, Component Side FRT – Pin 3 SIGRTN – Pin 4
| Yes | No |
| GO to DD67. | Key in OFF position. INSTALL a new FRPT sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. |
DD67 CHECK THE FRT AND SIG RTN CIRCUIT(S) FOR AN OPEN IN THE HARNESS
( + ) PCM Connector, Harness Side ( – ) FRPT Sensor Connector, Harness Side FRT FRT – Pin 3 SIGRTN SIGRTN – Pin 4
| Yes | No |
| REPAIR the open circuit. | GO to DD68. |
DD68 CHECK THE FRT CIRCUIT(S) FOR A SHORT TO SIGRTN OR GND IN THE HARNESS
| Yes | No |
| GO to DD69. | REPAIR the short circuit. |
DD69 CHECK FOR OPEN IN THE HARNESS
Point A FRPT Sensor Connector, Harness Side Point B FRPT Sensor Connector, Harness Side FRT – Pin 3 SIGRTN – Pin 4 - Access the PCM and monitor the FRT V PID.
Is the voltage less than 0.2 V?
| Yes | No |
INSTALL a new FRPT sensor. REFER to the fuel system WARNING information. Clear the PCM DTCs. REPEAT the self-test. | Key in OFF position. Remove the jumper wire(s). GO to DD70. |
DD70 CHECK THE SIGNAL AND SIGRTN CIRCUITS FOR AN OPEN IN THE HARNESS
( + ) FRPT Sensor Connector, Harness Side ( – ) PCM Connector, Harness Side FRT – Pin 3 FRT SIGRTN – Pin 4 SIGRTN
Are the resistances less than 5 ohms?
| Yes | No |
| GO to DD71. | REPAIR the open circuit. |
DD71 CHECK THE SENSOR SIGNAL FOR A SHORT TO VREF
| Yes | No |
DD72 DTC P0180: PERFORM A THOROUGH WIGGLE TEST ON THE FRPT SENSOR HARNESS
| Yes | No |
DD73 KOEO AND KOER DTC P0181: CHECK THE FRT_V PID
Is the voltage between 0.4 V – 4.5 V?
| Yes | No |
| GO to DD74. | The concern is elsewhere. RETURN to Symptom Charts, Symptom Charts for further direction. |
DD74 COMPARE THE PIDS AFTER STABILIZING THE VEHICLE TEMPERATURE
| Yes | No |
DD75 ARE DTCS P0182 OR P0183 PRESENT IN THE KOEO OR KOER SELF-TEST?
Are DTCs P0182 or P0183 present in the KOEO or KOER self-test?
| Yes | No |
| GO to DD79. | GO to DD76. |
DD76 KOEO AND KOER DTC P0181: CHECK THE COOLING SYSTEM
- Verify the cooling system is operating normally.
- Check the vehicle coolant level.
WARNING: TO AVOID PERSONAL INJURY DO NOT UNSCREW THE COOLANT PRESSURE RELIEF CAP WHILE THE ENGINE IS OPERATING OR HOT. THE COOLING SYSTEM IS UNDER PRESSURE. STEAM AND HOT LIQUID CAN COME OUT FORCEFULLY WHEN THE CAP IS LOOSENED SLIGHTLY.
Is the cooling system OK?
| Yes | No |
| GO to DD77. | REFER to Workshop Manual, Section 303, Engine Cooling for cooling system diagnostics. Repair as necessary. |
DD77 CHECK THE RESISTANCE OF THE FRP SENSOR WITH THE ENGINE OFF
( + ) FRT Sensor Connector, Component Side ( – ) FRT Sensor Connector, Component Side FRT SRtn
Is the resistance within specification?
| Yes | No |
| GO to DD78. | INSTALL a new FRT sensor. |
DD78 CHECK THE RESISTANCE OF THE CHT SENSOR WITH THE ENGINE RUNNING
- CAUTION: While conducting checks with a running engine ensure adequate safety precautions are observed to prevent contact with moving engine parts. For example; ensure ties or loose clothing do not come into contact with the cooling fan or drive belts.
- Vehicle must be at normal operating temperature.
| Yes | No |
Key in OFF position. Check the FRT & NG connector for damage or corrosion. Check the FRT % SRtn circuit(s) between the sensor and the NG module. Service as necessary | Key in OFF position. INSTALL a new FRT sensor. |
DD79 KOEO AND KOER DTCS P0182 OR P0183: CHECK THE TEMPERATURE SENSOR SIGNAL
- Access the NG and monitor the FRTMPAB PID.
Is the temperature greater than 125°C (257°F)?
| Yes | No |
Key in OFF position. GO to DD80. | Key in OFF position. GO to DD82. |
DD80 CHECK FOR A GROUNDED CIRCUIT
Is the temperature less than -20°C (-4°F)?
| Yes | No |
| INSTALL a new FRT sensor. | Key in OFF position. GO to DD81. |
DD81 CHECK THE SENSOR SIGNAL FOR A SHORT TO GROUND
( + ) FRT Sensor Connector, Harness Side ( – ) FRT Sensor Connector, Harness Side FRT SRtn - Measure the resistance between:
( + ) FRT Sensor Connector, Harness Side ( – ) FRT Ground
| Yes | No |
INSTALL a new NG module. (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM)). | REPAIR the short circuit. |
DD82 CHECK THE RESISTANCE OF THE FRT SENSOR WITH THE ENGINE OFF
| Yes | No |
| GO to DD83. | INSTALL a new FRT sensor. |
DD83 CHECK THE FRT CIRCUIT FOR A SHORT TO POWER
| Yes | No |
Key in OFF position. GO to DD84. | Key in OFF position. REPAIR the short circuit to PWR. |
DD84 CHECK THE FRT & SRTN CIRCUIT(S) FOR AN OPEN
( + ) FRT Sensor Connector, Harness Side ( – ) NG Module Connector, Harness Side FRT FRT SRtn SRtn
| Yes | No |
| GO to DD85. | REPAIR the open circuit. |
DD85 CHECK THE SENSOR SIGNAL FOR A SHORT TO SREF
( + ) NG Module Connector, Harness Side ( – ) NG Module Connector, Harness Side FRT SRef
| Yes | No |
DD86 CONTINUOUS MEMORY DTCS P0182 OR P0183: INTERMITTENT CHECK
- While observing the PID, carry out the following:
- Tap on the sensor to simulate road shock.
- Wiggle the sensor connector.
- Shake, wiggle, and bend the FRT & SRtn circuit(s). Check the FRT & SRtn circuit(s) between the sensor and the NG module.
Is there a large change in the temperature reading?
| Yes | No |
| ISOLATE the fault and REPAIR as necessary. | GO to DD87. |
DD87 CHECK THE FRT & NG CONNECTOR FOR DAMAGE OR CORROSION
Are the connectors and terminals OK?
| Yes | No |
The fault is not present at this time DISREGARD the current diagnostic trouble code (DTC) at this time. DIAGNOSE the next DTC. GO to Section 4, Diagnostic Trouble Code (DTC) Charts. | Repair as necessary. |
DD88 CONTINUOUS MEMORY DTCS P0182 OR P0183: INTERMITTENT CHECK
- Wiggle, shake, and bend small sections of the wiring harness while working from the FRT Sensor to the PCM.
Is there a large change in the voltage reading?
| Yes | No |
| ISOLATE the fault and REPAIR as necessary. | GO to DD89. |
DD89 CHECK THE FRT & PCM CONNECTOR FOR DAMAGE OR CORROSION
| Yes | No |
DD90 CONTINUOUS MEMORY DTCS P0190 AND P0191: CHECK THE FRP CONNECTOR FOR DAMAGE OR CORROSION
| Yes | No |
| REPAIR as necessary. | GO to DD91. |
DD91 CHECK THE SIGRTN, SREF, SRTN, AND VREF CIRCUITS FOR AN OPEN IN THE HARNESS
- For E-Series Dedicated NGV, and F-150 Heritage Bi-Fuel.
( + ) FRP Sensor Connector, Harness Side ( – ) FRP Sensor Connector, Harness Side SRef SRtn - For all others.
| Yes | No |
| GO to DD92. | For E-Series Dedicated NGV, and F-150 Heritage Bi-Fuel, GO to C25. For all others, GO to C1. |
DD92 INSPECT ALL THE VACUUM HOSES CONNECTED TO THE INTAKE MANIFOLD FOR LEAKS
| Yes | No |
| ISOLATE the fault and REPAIR as necessary. | GO to DD93. |
DD93 CHECK THE FRP PID
| Yes | No |
For Dedicated NGV and Bi-Fuel vehicles, GO to Pinpoint Test HB. For all others, GO to Pinpoint Test HC. | GO to DD94. |
DD94 COMPARE THE FRP PID TO THE MECHANICAL GAUGE
| Yes | No |
| GO to DD95. | For Dedicated NGV and Bi-Fuel vehicles, GO to Pinpoint Test HB. For all others, INSTALL a new FRP sensor. REFER to the fuel system WARNING information at the beginning of Pinpoint Test HC. GO to Pinpoint Test HC. |
DD95 CHECK THE FUEL SYSTEM AND FRP SENSOR CIRCUITS
- Check the fuel delivery system for concerns.
- Wiggle, shake, and bend small sections of the wiring harness while working from the FRP Sensor to the PCM.
- Check the FRP connector for damage or corrosion.
| Yes | No |
| ISOLATE the fault and REPAIR as necessary. | GO to Z1. |
