How does the wiring harness on the anti-lock brake control module unhook? Is there something I have to do to be able to pull it off? Did not want to pry on it too much. Was wondering if there is a release somewhere on it?
- Depress tabs on each side of connector cover, then
- Pull outward and upward on the lower half of cover until it locks into position pointing straight outward(2). Connector can then be pulled straight outward off ABM(1)
