AC will not blow 2012 Dodge Ram 3500
Dodge Ram 1500
The AC will not blow during the heat of the day. Once it cools off it works just fine. When it doesn’t blow air out the vents you can hear the motor going but no air.
The most common reason for this is a failing mode door actuator.
How to replace a blend door actuator on a 2010 dodge ram 1500
