Engine Swap 2002 Chrysler Town & Country
Chrysler town and country
I took the 3.8 good motor from my old 1999 town & country, and i bought a 2002 town & country with a 3.8 bad motor. Will the good engine from the 1999 fit in the 2002, and if so, what parts would not work, for the engine.
The engine will fit. However you will be giving up horsepower.
  • 1998–2000: 3.8 L EGH V6, 180 hp (130 kW), 240 lb⋅ft (330 N⋅m)
  • 2000-2007: 3.8L EGH V6, 215 hp (160 kW), 245 lb⋅ft (332 N⋅m)
The long block of each engine should be the same so all other existing components should bolt up with ease.
