Tried to smog my truck didn’t pass so I did a tune up. Replaced plugs, o2 sensor and was replacing the distributor cap and rotor when I noticed the distributor was broke. So I replaced it. When I got it all back together it ran fine but coded a crankshaft positioning sensor. So I replaced that and it is still coding the crankshaft positioning sensor. I don’t know what to do now.
Chevy Code P0336 – Crankshaft Position (CKP) Sensor Performance
Chevy Code P0366 Description
The Crankshaft Position (CKP) sensor sends a reference signal to the Vehicle Control Module (VCM) in order to indicate the crankshaft position and the RPM so that the VCM can determine when to pulse the ignition coil, the fuel injectors, and the control ignition timing. This is a type D DTC.
Conditions for Setting the DTC
- The Crankshaft Position sensor signal is missing for at least 0.5 seconds.
- Engine cranking and the VCM receives 4 or more Camshaft Position signals without a Crankshaft Position sensor signal.
Action Taken When Code P0336 Sets
The VCM stores the DTC in History if the VCM detects an intermittent problem.
Conditions for Clearing the MIL/DTC
A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles (the coolant temperature has risen 40°F from the start-up coolant temperature and the engine coolant temperature exceeds 160°F during that same ignition cycle) or the scan tool clearing feature has been used.
Diagnostic Aids
A poor connection, rubbed through wire insulation, or a wire that is broken inside the insulation may cause an intermittent.
Thoroughly check any circuitry that is suspected of causing the intermittent complaint. Check for the following conditions:
- Backed out terminals
- Improper mating
- Broken locks
- Improperly formed or damaged terminals
- Poor terminal to wiring connections or
- Physical damage to the wiring harness
Refer to Intermittent Conditions .
How to Test Crankshaft Sensor Code P0366
The numbers below refer to the step numbers on the diagnostic table.
- This step determines if the VCM is receiving the Crankshaft Position sensor pulses.
- This step checks the ignition feed circuit to the Crankshaft Position sensor.
- This step checks the Crankshaft Position sensor low circuit.
- This step checks the Crankshaft Position Sensor.
| Step | Action | Value(s) | Yes | No | ||
| 1 |
Was the Powertrain On-Board Diagnostic (OBD) System Check performed? | — | Go to Step 2 | Go to Powertrain On Board Diagnostic (OBD) System Check | ||
| 2 | Does the vehicle start and continue to run? | — | Go to Diagnostic Aids | Go to Step 3 | ||
| 3 |
Is the test light ON? | — | Go to Step 4 | Go to Step 6 | ||
| 4 | Connect the test light between the CKP sensor ignition feed and the CKP sensor Low circuit. Is the test light ON? | — | Go to Step 5 | Go to Step 7 | ||
| 5 |
Is the duty cycle within the specified range? | 40%-60% | Go to Step 8 | Go to Step 9 | ||
| 6 | Repair the open or short to ground in the CKP sensor ignition feed circuit. Refer to Wiring Repairs in Engine Electrical. Is the action complete? | — | Go to Step 13 | — | ||
| 7 | Check the CKP sensor Low circuit for an open. Was the problem found? | — | Go to Step 11 | Go to Step 12 | ||
| 8 | Check for an open or short to ground in the CKP sensor (3X) signal circuit. Was a problem found? | — | Go to Step 11 | Go to Step 12 | ||
| 9 |
Is the reluctor wheel damaged? | — | Go to Step 13 | Go to Step 10 | ||
| 10 | Replace the CKP sensor. Refer to Crankshaft Position (CKP) Sensor Replacement . Is the action complete? | — | Go to Step 13 | — | ||
| 11 | Repair as necessary. Is the action complete? | — | Go to Step 13 | — | ||
| 12 | Replace the VCM.
| 13 |
Does the scan tool indicate that this diagnostic ran and passed? | — | Go to Step 14 | Go to Step 2 | ||
| 14 | Using the scan tool, select Capture Info and Review Info. Are any DTCs displayed that have not been diagnosed? | — | Go to the applicable DTC table | System OK |
