1998 Chevy Prizm scheduled maintenance overview
GEO Prizm
I got 4 new tires in June 2020. The last oil change I got was on December 6th, 2020. My car inspection was on March 29th, 2021. I also got my tires rotated a couple of months ago. My current mileage is 144,233. My question is when should I go in for a car maintenance check again?
127500 Miles
Engine Oil Filter R&R
Engine Oil Drain & Refill
Tire Rotate
Notes: Do not rotate staggered tires from front to back. If tires are asymmetric(directional), do not rotate side to side. Follow all OEM tire rotation recommendations and pattern.
Body Latches, Locks & Hinges Inspect
Notes: Includes: shift linkage, hood latch, door latches and hinges, parking brake cable guides, underbody contact points.  After inspection lubricate component(s) as required.
Weatherstrip Seal Inspect
135000 Miles
Accessory Drive Belt Inspect
Notes: Adjust if necessary.
Cooling System Leak Inspection
Tire Rotate
142500 Miles
Tire Rotate
150000 Miles
Spark Plugs R&R
Tire Rotate
Engine Air Filter Element R&R
Notes: Service more often when operated in dusty conditions.
Engine Coolant System Drain, Flush & Refill
Fuel Tank Filler Cap O-Ring Inspect
Notes: Replace if necessary.
Fuel Line Inspect
