Trunk Lid will not pull down Lincoln Town Car Video
trunk wont pull down
I went out to the grocery store and after I put my stuff in the trunk to leave it wouldn’t shut all the way. The trunk does latch but no longer pulls down like it used to. I tried it again when i got home and still the trunk will not pull down.
Lincoln Town Car Trunk Won't Close *SOLVED* #lincolntowncar #fordcrownvictoria
This is a classic description of a faulty trunk latch motor assembly. You will need to replace it. And if you have a few tools you should be able to do it yourself. Check out the video to see just how easy it is.
How to replace Trunk Latch Motor
Removal
  1. Open Trunk
  2. Remove 6 Trunk Carpet Retainers at rear of trunk
  3. Pull Carpet over latch to gain access to trunk motor assembly
  4. Disconnect electrical connector
  5. Remove 3 retaining bolts
Install
  1. Install in reverse order
