my car has 193,000 miles on it. runs and shifts fine and no leaks. I am the second owner. I checked my transmission fluid after running the car for 15 minutes and it is on the minimum for Cold. It has a CVT transmission. I am a senior on fixed income and am trying to just make it last another 6-12 months. I cannot find any mechanics that will add Mitsubishi fluid for me due to the mileage on it. Will it harm it to add Mitsubishi approved CVT fluid just to make it another 6-12 months?
Topping off your transmission with genuine Mitsubishi-approved CVT fluid will not harm your car, provided the fluid level is actually low. Adding a small amount of fresh fluid to bring it to the proper level is completely safe and different from doing a full transmission flush, which is what mechanics avoid on high-mileage vehicles.
Before you add any fluid, double-check how you read the dipstick, as CVT fluid expands significantly when warm and overfilling can cause damage.
How to Double-Check Your Fluid Level
- Check when fully hot: Running the car for 15 minutes usually warms the transmission fluid well past the “Cold” range. You should check the fluid again after a 20-to-30-minute drive so the transmission reaches full operating temperature, then look at the “Hot” hash marks on the dipstick.
- Follow the exact checking steps: Park on a level surface and leave the engine idling. Shift slowly through every gear (P-R-N-D-L) and back to Park, then wipe the dipstick, re-insert it fully, and pull it out to read the level.
- Only add if it is below the Hot mark: If the fluid sits at the “Cold” mark while the transmission is warm, it is likely underfilled. If you accidentally checked a different dipstick (like engine oil) or if the transmission wasn’t warm yet, you want to be certain before pouring anything in.
Why Mechanics Say No (and Why Topping Off Is Safe)
- Flushes vs. Top-offs: Mechanics refuse to service transmissions with 193,000 miles because a full drain or flush can dislodge debris and cause an old transmission to slip. They avoid touching high-mileage CVTs to protect themselves from liability if the transmission fails afterward.
- Topping off is low-risk: Adding a half-quart or one quart of fluid to replace what has slowly evaporated over time will not dislodge debris. It simply restores proper hydraulic pressure so the CVT belt does not slip.
Safe Steps to Top Off Your CVT
- Buy the exact fluid: Purchase genuine Mitsubishi DiaQueen CVT Fluid J4 (or J1, depending on your car’s year and owner’s manual) from a Mitsubishi dealership parts counter or reputable auto parts store. Never use generic “universal” transmission fluid in a Mitsubishi CVT.
- Add in very small amounts: Use a clean, long-necked funnel to pour the fluid into the transmission dipstick tube. Add only 4 to 6 ounces at a time, as CVTs are very sensitive to being overfilled.
- Recheck between pours: With the engine idling in Park, wait two minutes for the fluid to settle down the tube, then recheck the dipstick. Stop as soon as the fluid reaches the middle of the Hot range.
