2005 dodge caravan se 3.3lMay 15, 2015how do I empty the fuel tank without taking it out?Keywords:CaravanFuel tank without taking it out1 thought on “2005 dodge caravan se 3.3l” Freeautomechanic May 18, 2015 at 7:38 am Disconnect the fuel filter and use a jumper wire to supply power to the fuel pump relay and the fuel pump will pump it out of the line for you.Comments are closed.previous2001 ford windstarnextBMW 328iconv
