Acceleration problems
Hi my name is Jason. I have a 1995 Chevy Caprice classic and I’m having engine problems when i hit the accelerator my car goes 5,6,7 mph and at random moments has a boost of power and goes normal speed 80 – 100 mph what would be the problem i changed the gas filter the spark plugs and nothing… if needed more info just ask
First thing I would do is check for codes. Since this is a 1995 OBD I it can be done without a Scan-tool. And the instructions and codes can be found right here on this site: http://freeautomechanic.com/diagnostictroblecodes5.html
Let me know what codes come up and we’ll go from there
Sounds like an air leak in the hoses. check the hoses around the top part of engine toward the firewall. You should hear a hissing sound. Test the hoses. Test each one.
