No heat in 95 camaro
The heat in my 95 camaro 3.4 liter V6 is not working. I have changed the thermostat and flushed the system and have no symptoms of a bad or leaky heater core, what else could it be?
1 thought on “No heat in 95 camaro”
  1. Might be a simple as an air pocket in the system. You need to make sure to use the bleeder valves when topping off the coolant after flushing the system.
