I have a 1996 Z71 Pick up truck 4wd. At any moment (usually traveling 50-60 mph) the speedometer will begin dropping to zero. The dash lights will light up leaving the ABS light to stay on. You have steering control but when you press down on the gas, the engine raves up. Then all of a sudden, it will ‘kick’ in and you continue driving like normal. Sometimes it will immediately correct itself while other times, you best pull over and wait for it to ‘kick in’. Yesterday, when it did it the speedometer would not work until it ‘kicked’ in. It may to it today but not at all tomorrow.
No acceleration, lights crazy then kicks in & we go?
Sounds like an electrical issue. Could be a failed sensor and a combination of low on fluid in the transmission. With the ABS light staying on it may be related to the VSS : http://www.freeautomechanic.com/vss-vehicle-speed-sensor.html
Best to scan for check engine and ABS codes and go from there with this one.
THANK YOU SO MUCH! It was exactly the problem – Vehicle Speed Sensor!!!! You Rock!
