Home » Car Questions » 2001 Malibu ignition locked
Key goes in and out ok but will not turn to start. I’ve seen where this model has a lot of ignition problems but this seems like a safety lock is not releasing. I can’t get it out of Park if the key won’t turn and I’ve wiggled the wheel and even rocked the car back and forth while trying to turn the key. Is the problem in the key cylinder or switch or is there saftey lock to check and where is it? Thanks Mike
1 thought on “2001 Malibu ignition locked”
  1. You want to rock the steering wheel side to side a bit when trying to turn key. Also make sure the Shifter is fully in park. And if you have a spare key, try it.
    If none of these help, you are looking at needing the Key Lock cylinder replaced.
