ford galaxy ghia,1995,autoMay 2, 2010May 2, 2010hi,the speedo works fine to 80 then after that it bounces from side to side,whyKeywords:Speedometer cluster1 thought on “ford galaxy ghia,1995,auto” Jaxer May 2, 2010 at 10:29 am If this is a cable type speedo, the gauge itself will need to be replaced. If this is a electronic style, remove the sensor and clean it and see if that doesn’t correct the issue.Comments are closed.previousToyota Diesel 3BnextHi, I have a 2003 Kia Spectra and today it decided to stop blowing cool air. DOes anyone have a quick fix or do I have to take it to mechanic?
