Jeep transmissionJune 28, 2010June 29, 2010Can you operate 1999 Jeep Cherokee sports auto trans with the TCU disconected ? Keywords:Transmission 2 thoughts on “Jeep transmission” Freeautomechanic June 29, 2010 at 6:21 am I do not think it would shift at all since it is and electronic shift transmission that needs to be controlled by the TCU. rod woolford June 29, 2010 at 8:02 pm In the service manual it says to check the trans by taking out the fuse in the TCU harness drive the car doing your tests Comments are closed.
