2002 Dodge Caravan Fuel Problem
After the AC technician finished AC repairs and recharge, the engine 3.3L  stopped running and a gas odor came from somewhere under the vehicle. Inspection of all gas lines showed no leaks. Fuel pump came on, but no fuel pressure present at the injectors. The scan tool showed a circuit problem with the No. 1 cylinder. Fuel filter is okay as well. Still no fuel present at the injector fuel rail.
derrumbe
View Comments
  • (QUOTE)but no fuel pressure present at the injectors.
    (Quote)Still no fuel present at the injector fuel rail.
    Check for blown fuses, circuit breakers, or fusible links. Confirm an operational ASD relay.
Recent My Questions
Transmission Fluid to CVT 2017 Mitsubishi Outlander
my car has 193,000 miles on it. runs and shifts fine and no leaks. I am the second owner. I…
2 days ago
Black Soot on Concrete from 2003 Jeep Wrangler Rubicon
Hi Jaxer. I have sent you messages on YouTube as well. Appreciate your content. I notice that when my jeep…
2 months ago
HVAC Actuators 2006 Jeep Wrangler X
duct control stepper motors? HVAC Air Door Actuator R&R Warning: On vehicles equipped with air bags, disable the air bag…
2 months ago
2008 Chevy Colorado Headlamp Bulb Replacement
Removal Procedure Caution: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass…
3 months ago
1991 Dodge Dakota 5.2 surges at low rpm
My vehicle surges at low rpm. There are no vacuum or fuel leaks and a new IAC made no difference.…
4 months ago
How to Replace Thermostat 3.6L Chevy/GMC – Code P0128
Thermostat Housing for 2017-2022 Chevrolet Colorado or GMC Canyon with the 3.6L engine. This repair took care of the check…
9 months ago
