Home » Car Questions » 1990 geo prizm
1990 geo prizm
rear tire sticks out more than the rest new tires this just happened
3 thoughts on “1990 geo prizm”
  1. I AM WORKING ON A 1990 GEO PRIZUM THAT HAS A HARD CODE 22 I HAVE TESTED THE CONECTOR AT THE COOLANT SENSOR AND THERE IS NO 5 VOLT REFERANCE SIGNAL I NEED TO TRACE BACK TO THE ECU FOR VOLTAGE I NEED TO WHICH CONECTOR AND WHICH WIRE TO TEST OUT OF THE ECU
