need cam timing for 93 camry 2.2 engine,as i need remove the cams to get the head bolts,need cam timing marks to reinstall
93 camry
Prior to timing belt removal, make sure all the matchmarks are there — 2VZ-FE and 3VZ-FE engines
Align the timing marks to set No. 1 cylinder to TDC
If the timing marks are not aligned, turn the crankshaft one full revolution (360 degrees)
For step by step instructions click on the “Repair Manuals” tab to your left
