Home » Car Questions » 1991 Lincoln has disco lights
Hoping someone can help.  The lights on my Towncar have gone haywire.  I’m sure its a short in the wiring, but I was hoping to start with the fuses.  Any idea where I might locate a fuse box diagram? (Most immediate problem is marker lights are staying on even if car is turned off.  Having to disconnect battery and that doesn’t seem like an ideal solution.)  I admit I’m an idiot!
1 thought on “1991 Lincoln has disco lights”
  1. The easiest place to find a fuse bax diagram is in your owners manual under “fuses”. If you are looking for more of a wiring diagram, click on the “Wiring Diagrams” tab to your left.
