1990 jeep cherokee hard brake pedal please help
1 thought on “1990 jeep cherokee hard brake pedal please help”
  1. Brake pedal feel is firm, but brakes lack sufficient stopping power or fade
    1.Check the operation of the brake booster and brake booster check valve. Replace worn or failed parts.
    2.Check brake linings and brake surface areas for glazing and replace worn or damaged parts.
    3.Check for seized hydraulic parts and linkages, and clean or replace as needed.
    http://www.freeautomechanic.com/brakes.html
