i need to replace my transmission in my 93 olds cutlass supreme but i cannot get the axle out of the drivers side there r bolts around it but im not sure if i need to remove em to get it out can someone gimme some tips thanx
Best thing to do would be to click on the “Auto Repair Manuals” tab tot the left and get the step by step procedure. You may need to knock it out with the use of a block of wood. This is assuming you have removed everything else that is required.
