How do I get the trans-axel to fit back in the car without either hitting the frame or damaging the new clutch? There seems to be no room to fit it back in. Is there some trick my Eclipse repair manual doesn’t tell me?
I most cases the sub-frame id dropped down out of the way when the trans is removed and the engine is left hanging with proper support. Should be just as much room putting it back in as there was taking it out….
