1997 Lincoln Continental
I had my transmission serviced, less than a 100 miles later it started to slip, checked the fluid and was low filled didnt get any better, 200 miles later it is shot my question is should the mechanic that serviced it have seen any problems
1 thought on “1997 Lincoln Continental”
  1. Only thing that might have been a warning would have been a leak of some kind or if the fluid was BLACK in color. Any time you have a service performed it is a good idea to keep an eye on it and check your fluid levels for the next few days to make sure all is well. Also keep an eye on where you park the car as it helps to identify when a leak has started.
