When I am stopped and have to go from first to second gear I get a little noise and vibration from the clutch. No problems in going to third, fourth or fifth gear. I have been told everything from motor mounts to flywheel, to master slave cylinder to adjustment of clutch cable adjuster nut. Anyone have any ideas?
2000 Hyundai Sonata GLS 5 Speed
First thing to do would be to check your Hydraulic Clutch Fluid Level. If it is low or getting close to empty it is time to replace the clutch disc. If it is empty, you may have a leak in the system and will need to fix the leak.
These systems are sealed and should not require any fluid to be added. If it is low, it is because the materiel is warn and once the clutch is replaced the fluid level will come back up.
