In cold weather and cold starts. Engine stalls at stops. Slowing down between 15 mph and 0 mph engine stalls. Slowing down to make a turn engine will stall during turn. Lose steering ability when engine stops.
If the check engine light is on, I would assume with this issue there would be. The first thing to do would be to get the codes and post them back here in the comments so I can further assist you.
May be as simple as a vacuum leak or a failing sensor but having the codes would be helpful.
