replaced the crank sensor just after the transmission, now it cranks but doesn’t start, can you show me where all the sensors are located
1991Pontiac 6000Le
Do you have the 2.5L engine or the 3.1L V6 engine?
If you have a check engine light on, you can pull the codes yourself, here is how: Pontiac OBDI Trouble Codes
