1996 mercury sableJanuary 23, 2015oil in intake I replaced gasket and seals you think engine gasket nextKeywords:Sable1 thought on “1996 mercury sable” Freeautomechanic January 23, 2015 at 8:12 am Oil setting on the intake, would replace valve cover gaskets. Engine oil in the intake… not likely to happen unless the intake is cracked or the PCV is stuck open and the oil level is over filled.Comments are closed.previoussebringnext04 dodge stratus
