Concerning the impreza is the head suppose to move, I was told its not supposed to move. I just want the timing belt changed, but the guy working on it says he can’t put it back together because the head is loose. Please help!
If the guy you took it to won’t do the work, you will have to take it somewhere else.
I have never heard of a head being loose. A cylinder head has many bolts that are torqued down and they do not move.
If the vehicle ran when you took it in for the timing belt, I would pick the car up and RUN to a different mechanic.
If you have further questions about this situation please respond in the comments below.
