citreon relay
the heating is working but not clearing the windsceeen, hot air blasts out everywhere else but not onto the windsceen.
i imagine a direction flap has busted or something.
is there someway i can fix it myself
1 thought on “citreon relay”
  1. I feel you are on the right track with your diagnosis. If you feel comfortable tearing into the dash to see if there is a restriction or just a failed mode door actuator, then yes you can do this yourself. If you do not feel comfortable taking the dash apart, steer it into the local shop for the repair.
