1999 Ford Explorer Eddie Bauer Edition
Can a 130 amp alternator be used instead of the standard 95 amp alternator without any adverse effects?
1 thought on “1999 Ford Explorer Eddie Bauer Edition”
  1. Sure it will charge the battery and run the engine however, it will not do as an efficient job when the stereo and amplifier are used along with the heater, rear defogger, and other accessories.
    The vehicle is not designed to use the lower amp alternator for a reason and would recommend using the original higher amp alternator if possible.
