I’m at a loss. I have had a mechanic check all the electical components that are involved in starting my car. I have a new ignition control module today. Car has no spark. I’m wondering even if the distributor and coil have power, could they still be bad. I gotta new cap and rotor button also. He tested all the fuses for the car too. I’m open to any idea….
1993 Nissan Altima
No Start Diagnostics
If it has no spark and no injector pulse.. check crank sensor and then ECM.
If it has injector pulse, Check ECCS Relay, then power and grounds to ECM. Then Check Condenser and power Transistor that supply power to the coil. Then check the distributor itself.
