Home » Car Questions » Hyundai Sonata 2011
Hyundai Sonata 2011
Burning to much gas. Burned 23 gallons to drive 36 miles what can be done to get better mileage.
1 thought on “Hyundai Sonata 2011”
  1. that isn’t even 2 miles per gallon, you must have a severe fuel leak. If you do not smell gas, I am certain you are seeing excessive smoke. This is almost impossible to do without noticing huge amounts of smoke or seeing fuel leaking on the ground.
    Keep Your Engine Properly Tuned
    Fixing a car that is noticeably out of tune or has failed an emissions test can improve its gas mileage by an average of 4 percent, though results vary based on the kind of repair and how well it is done.
    Fixing a serious maintenance problem, such as a faulty oxygen sensor, can improve your mileage by as much as 40 percent.
    Fuel Economy Benefit:
    4%
    Equivalent Gasoline Savings:
    $0.12/gallon
    save
    Check & Replace Air Filters Regularly
    Replacing a clogged air filter can improve your car’s gas mileage by as much as 10 percent. Your car’s air filter keeps impurities from damaging the inside of your engine. Not only will replacing a dirty air filter save gas, it will protect your engine.
    up to 10%
    up to $0.29/gallon
    save
    Keep Tires Properly Inflated
    Sample tire pressure label
    You can improve your gas mileage by around 3.3 percent by keeping your tires inflated to the proper pressure. Under-inflated tires can lower gas mileage by 0.4 percent for every 1 psi drop in pressure of all four tires. Properly inflated tires are safer and last longer.
    up to 3%
    up to $0.09/gallon
    save
    Use the Recommended Grade of Motor Oil
    API energy conservation label. You can improve your gas mileage by 1-2 percent by using the manufacturer’s recommended grade of motor oil. For example, using 10W-30 motor oil in an engine designed to use 5W-30 can lower your gas mileage by 1-2 percent. Using 5W-30 in an engine designed for 5W-20 can lower your gas mileage by 1-1.5 percent. Also, look for motor oil that says “Energy Conserving” on the API performance symbol to be sure it contains friction-reducing additives.
    1-2%
    $0.03-$0.06/gallon
    Save
    Note: Cost savings are based on an assumed fuel price of $2.91/gallon
