2001 Dodge ram Van 318May 14, 2015Starts up then it dies may run all day then I will stop and start back up that diesKeywords:Ram VanStarts up then it dies may run all day then I will stop and start back up that dies1 thought on “2001 Dodge ram Van 318” Freeautomechanic May 15, 2015 at 9:04 am Is the check engine light on? You will need to pull the codes, most local auto parts stores will do this for free.Could be as simple as a vacuum leak, or the IAC sensor that controls the idle speed.Comments are closed.previouslotus eclat 1977nextChrysler 300
