Home » Car Questions » 2002 f150 4.2 motor
2002 f150 4.2 motor
codes 1131 1151 truck is running rough and sometimes wont start
1 thought on “2002 f150 4.2 motor”
  1. Through the Oxygen (O2) sensor, the Engine Control Module (ECM) has detected a lean system, which means that there is either not enough fuel or and excessive amount of air in the system. Start by checking for vacuum leaks.
    P1131 Ford – Lack of Upstream Heated Oxygen Sensor Switch Sensor Indicates Lean Bank 1
    Possible causes
    – Faulty Oxygen Sensor
    – Vacuum leak affecting bank 1 only
    – Fuel injector problem bank 1
    – Check for cylinder misfire on bank 1
    – Engine mechanical condition
    P1151 Ford – Lack of Upstream Heated Oxygen Sensor Switch Sensor Indicates Lean Bank 2
    Possible causes
    – Fuel pressure high or low
    – MAF sensor dirty/defective
    – Vacuum leak on engine
    – Leaking fuel injector or fuel pressure regulator
    – Faulty Powertrain Control Module
