04 pt cruiser base modelJuly 23, 2015July 24, 2015Will the engine knock real deep sound is it the timingKeywords:PT Cruiser1 thought on “04 pt cruiser base model” Freeautomechanic July 25, 2015 at 9:02 am A deep engine knock is usually the crank or rod bearings. A knock at idle that goes away when you rev the engine is generally the crank bearings. A knock that gets louder when you rev it is usually the rod bearings.Comments are closed.previous1989 gmcnextnissan pulsar 1993
