as soon as you start car up digital readout says it won’t allow the AC to blow because the car is overheated. after it runs a little bit the heat gauge Arm does not move at all. air condition An gauge everything worked perfectly the drive before. AC will not cool now.
cAR is not getting hot nor has it ever.fluid is full aND definitely not hot
I would start with the temperature sensor(sending unit) since you said the gauge doesn’t move and the computer thinks it is overheating. Must be getting a false signal.
