2005 inf.G35
My inf.g35 runs hot sitting still when the air condition is on
1 thought on “2005 inf.G35”
  1. Check your high speed fan to make sure it is coming on when you turn on the Air Conditioning. If it is not(which is what i suspect) you will need to test the fan and the high speed fan relay. There are 3 cooling fan relays and 2 fan motors. If you have no power to the relays, check the fuses.
