Drivers door window will lower when door is opened. When the door is closed the window will not go back up as Volvo windows do when convertible door is opened. I have to raise window with door switch every time I enter car. Window only drops down about a 1/4 inch as it always did. Does door window switch need replacement?
I would lean more toward the door latch switch. If computer thinks the door isn’t shut, it wouldn’t allow it to go up automatically. I am going to assume the problem is on the drivers side only and the passenger side works as it should.
